Grasshopper C# VRay.GetState
  • Grasshopper C# VRay.GetState
    Is there a way to get the current state of a VRay Next rendering, from a C# component in Grasshopper? (IDLE, FINISHED etc.)
    (The rendering is triggered in Rhino)
    Using the .Net SDK I can do this, which will print "IDLE_DONE":
    VRay.VRayRenderer renderer = new VRay.VRayRenderer();
    renderer.StartSync();
    renderer.WaitForRenderEnd();
    Print(renderer.GetState().ToString());
    Here obviously I set up a new VRay object and it renders an empty scene.
    So another way to ask my first question:
    Is there a way to reference the VRayRenderer object that was created when setting up the rendering in Rhino?
    I hope the question makes sense...
    All the best,
    Joakim
    Hi Joakim,
    If understand correctly, the short answer is: yes.
    There is a C export from the plugin binary that can be called from C#. Since they live in the same process, importing a method from the .rhp to C# will access the correct memory segment (since the .rhp is already loaded)
    Click image for larger version  Name:	getrenderstate.png Views:	1 Size:	277.9 KB ID:	1045620
    The C# code here is very simple:
    Code:
      private void RunScript(object x, object y, ref object A)
        RendererState state = (RendererState) ImportInterface.GetRendererState();
        Print(state.ToString());
      // <Custom additional code>
      enum RendererState {
        FatalError = -1,
        IdleInitialized,
        IdleStopped,
        IdleError,
        IdleFrameDone,
        IdleDone,
        Preparing,
        Rendering,
        Paused,
        AwaitngChanges
      public static class ImportInterface
        [System.Runtime.InteropServices.DllImport("VRayForRhino.rhp")]
        public static extern int GetRendererState();
      // </Custom additional code>
      Thank you so much! As long as I don't check too frequently and do a few extra checks if the value has changed this works as well as VRayRenderer.WaitForRenderEnd()
