Vray Next Rhino FUR shape
  • Vray Next Rhino FUR shape
    I would like to create a straw using V-ray fur. I don't see where can be the individuals set to be flatten. By now I'm only getting circular section (if I'm not wrong with the previews Vray I was able to flatten the fur strands)..
    Is it something I don't see or it is not doable?
    thank you
    I'm actually getting into something like this... The main goal the to have the straws as flat as possible.
    Occasionally can you name a material I can grab from the existing library that would match the reference image?
    thanks for your help
      To achieve flat fur strands, you need to use a V-Ray Hair material in the Fur asset's material slot.
        Originally posted by georgi.georgiev View Post
        YEP! nice
        thank you
