It's a indigo material that I want to use in vray. So I downloaded the file and insert this in the diffuse and the reflections map.
Fresnel ON , and IOR set to 3.
This is what I have then.
Not just what I want. Someone know how to do this ?
You can try with the Iron Blurry 5cm material from our built-in library.
Changing its Reflection color and glossiness can alter its appearance.
You can also disable the bump or replace it in case that's necessary.
