Vray next 4.2.001, Crash of open vfr 2.x of rhino 5 file at Rhino 6 sr24 & rhino 7 Wip, why?
  • Vray next 4.2.001, Crash of open vfr 2.x of rhino 5 file at Rhino 6 sr24 & rhino 7 Wip, why?
    As topic.
    Anyone have a same problem? Thank you!
    Hello,
    Have Rhino crash is definitely not an acceptable behavior regardless of the version of V-Ray that was used to make the scene.
    If you haven't already, could you please send over the project file for investigation to support@chaosgroup.com ? You can do so by using the Rhino menu V-Ray > Pack Project and then share the archived file via a file-sharing service of your choice.
    The following info would also be of great help in the investigation:
    - your OS version
    - list of 3rd-party plugins used in Rhino beside V-Ray
    - when the crash occurs (at file opening / initializing render process / finish render process / etc)
    - Rhino crash dump file
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      There have a any update of this problem? The rhino crashed when I open all the old file with the invalid name of vray material?
      My Vray is 4.2.002
        Hi pun1407
        Could you please share the file with us so we can investigate in detail? If this is alright, please send an archived copy (V-Ray > Pack Project) via email or a file-sharing service to support@chaosgroup.com
