GPU - how to use the Max Trace Depth of materials?
  • GPU - how to use the Max Trace Depth of materials?
    if the GPU mode is enable than the global Max Trace Depth can't be disabled anymore. How can the user switch to the Max Trace Depth of the materials?
    -Micha
    There is a difference in how the trace depth limit works on CPU and GPU.
    CPU:
    - Keeping the trace depth disabled lets you specify the value in every material separately
    - Enabling the trace depth will override the material values, forcing the global trace depth for all of them
    CPU Example:
    If a material has trace depth lower than the global limit and the global limit is enabled - the global value is used.
    If a material has trace depth higher than the global limit and the global limit is enabled - the global value is used.
    GPU:
    - The trace depth can't be disabled
    - Setting the trace depth will not override the depth of individual materials - it's works as a global max.
    GPU Example:
    If a material has trace depth lower than the global limit - the material value is used.
    If the material depth is higher - the global is used.
    As a conclusion:
    When rendering on the GPU it's safe to keep the global limit high as long as you take care of the material values.
    Regards,
    Konstantin
      Very interesting. Thank you for the quick answer.
      Could be good if this info could be added to the help page.
