UVW Placement
  • UVW Placement
    Hi im trying to use the UVW Randomizer which should be able in Vray5 for Rhino. I found the UVW Placement texture but can anyone tell me how i can make it work? Thanks alot! Cheers, Felix
    Hi felix_landwehr
    To apply the UVW Placement Texture to a bitmap, you will need to choose Type: Mapping Source and select UVW Placement in the UV Placement Source. I've prepared a short gif for better visual understanding: http://ftp.chaosgroup.com/support/sc...9_09-16-28.gif
    From there, you can adjust the placement settings as you wish.
    You can find more information on the Randomization Parameters (as well as some great visual examples) here: https://docs.chaosgroup.com/display/...tionParameters
    Nikoleta Garkova | chaos.com
      Hi Nikoleta,
      thanks a lot!! Exactly what i needed
      Cheers, Felix
