Batch Render & Snapshots
  • Batch Render & Snapshots
    Hi There,
    With Vray 5 and Rhino 7, is it possible to render a batch series using the saved snapshots?
    It seems very cumbersome to have to save multiple files of the same object if you want to change lighting or materials. Snapshots or layer states allow this to happen.
    Cheers
    Hello,
    Currently the Batch Render tool will only register snapshots from the currently loaded model.
    After opening the V-Ray Batch Render window, right click on the window and select Add Current model.
    Click image for larger version  Name:	Image2.png Views:	0 Size:	10.0 KB ID:	1100176
    After that the snapshot options should be visible.
    Click image for larger version  Name:	Image1.png Views:	0 Size:	11.6 KB ID:	1100175
