Vray 3.6 Blend Mode and Displacement
  • Vray 3.6 Blend Mode and Displacement
    Is there a way to use displacement with the blend mode in 3.6? Also, does anyone know if the help docs are still available for 3.6?
    Thanks
    Hello, jvparc ,
    Displacement from materials slotted within a Blend material cannot be displayed in V-Ray 3.6 for Rhino. The displacement itself actually operates on the object level, not material.
    As a workaround, you can try adding extra layers to a Generic material and use an opacity mask to simulate the same function as a blend material. The displacement texture you use can be edited by slotting it within a 'Mix (Map)' texture and blending it together with the opacity texture.
    As for the V-Ray 3 for Rhino documentation, it is not available for browsing online but you can download it archived here: https://docs.chaosgroup.com/display/...hived+Versions
    Kind regards,
    Peter
    Peter Chaushev
    V-Ray for SketchUp | V-Ray for Rhino | Product Specialist
    www.chaos.com
