VRAY Material Creation
  • VRAY Material Creation
    Kindly point me in the correct direction to create a VRAY material that looks like the attached file called Bricks Aligned (note some perspective correction is still required). The VRAY brick materials in the library are offset (the way a proper bricklayer would set them) and there isn't a material that looks like the one I need. Obviously I need a proper bitmap, but what other components will be required to get a good result?
    Thanks,
    Thomas Click image for larger version
Name:	Bricks Aligned.jpg
    Hello Thomas,
    Just take any Tile / Bricks material from the library and adjust colors and tile texture parameters. Your question is answered by Pattern Type parameter.
    No bitmap needed.
    More info in the official doc:
    https://docs.chaosgroup.com/display/VRHINO/Tiles
    Cheers
