Missing Layers in VFB
  • Missing Layers in VFB
    Using the latest version of V-ray for Rhino (vray_51004_rhino_win_x64). As of this AM today I have lost the Layers setting in the VFB. I understand in the past there was some way to reset the VFB window when it is not running correctly? Found my problem. On resizing the window I must have hidden the Layers window.
    Last edited by wmc; 01-06-2021, 07:06 AM. Reason: Found the issue I was having. User error :)
    Hi wmc,
    Great to hear you've managed to solve that! Another general tip - if you are not able to see the layers panel, you might also try the shortcut command Ctrl+L;
    You can reset the VFB state by going to C:\Users\<username>\AppData\Roaming\Chaos Group\V-Ray for Rhinoceros and deleting the FrameBufferState.fbs file.
    Nikoleta Garkova | chaos.com
