See what material an object has
  • See what material an object has
    Is there a quick way to see what material is assigned to an object? Sometimes just looking at it isn't enough.
    Thanks
    jvparc
    I think the attached is what you are after. "edit vray material". Click that icon, then the item.
    Glenn
      Hi jvparc,
      What Glenn mentioned is exactly right!
      And the other way around - going in the Asset Editor and right-clicking on a material, there is a 'Select Object In Scene' option.
      Nikoleta Garkova | chaos.com
        The material name can also be seen at the Rhino object material options.
          Thanks everyone --- the material wasn't showing up in the Rhino object material options for some reason, that's what was throwing me off.
