rendering subd directly from grasshopper
  • rendering subd directly from grasshopper
    Hello,
    it seems here that is not possible rendering the subd objects directly from grasshopper. I'm doing something wrong or it is an actual limitation? thanks, Roy
    Hi Roy,
    It should be possible to use SubD from Mesh or vice-versa in GH and render it out with V-Ray, see attached (very) simple example.
    Can you share what you're trying to achieve to see if there are any issues just in case? Thanks!
    Nikoleta Garkova | chaos.com
      HI Nikoleta,
      now it works perfectly. I was missing the conversion from Subd to meshes before rendering,
      thanks,
      ciao,
      Roy
        Good to hear! Do let us know if you have additional queries.
