applied material not visible in rendermode
  • applied material not visible in rendermode
    Dear Team,
    since the update i can't see the applied materials in the rendermode.
    its only white, but if i render, you can see the material. its difficult to apply a mapping, because its not visible.
    I just found a workaround by activating the "bump" by inserting the same image for the material.
    does anyone else has the same issue?
    thanks! BR
    Hi eybl_eybl,
    Can you check this thread to confirm if you are referring to the same issue? If so, enabling/disabling the bitmap slot should suffice as a workaround, and do expect an update soon.
    Nikoleta Garkova | chaos.com
