Normal map type - DX x GL
  • Normal map type - DX x GL
    Hello,
    what's the correct normal map for V-Ray? Polyhaven offers both "DX" and "GL" option and they seem to be inverted.
    https://polyhaven.com/a/stone_brick_wall_001
    Thanks
    Jonas
    Use the purplish one/ the GL one.
    The map may seem inverted(don't mind it) but when you render it should be fine.
      Thanks, Slavcho!
        Hi Jonish,
        In V-Ray the following should be true for a normal map to render correctly (V-Ray for 3ds Max is an exception):
        • The Red channel should be pointing right
        • The Green channel should be pointing up
        This texture for example looks correct:
        Click image for larger version  Name:	Normals01.JPG Views:	0 Size:	200.0 KB ID:	1135167
        Konstantin
