How to rotate UV per object while using the same VRAY Material?
  • How to rotate UV per object while using the same VRAY Material?
    I want to rotate the UV of a VRay Material applied to multiple objects, but I cant seem to find out the parameter to do so. In the example image, I want all the wood grain to run horizontally instead of vertically.
    Click image for larger version  Name:	image.png Views:	0 Size:	591.1 KB ID:	1163814
    I've tried all the rotation parameters under Texture Mapping in Rhino and I see no changes in the VRay interactive view.
    Funny enough, ​if I rotate the actual object, the UV will rotate also, BUT if I then stretch the object back to it's pre-rotated shap using ControlPoints edit, the UV will automatically rotate back to the "not desired" direction.
    So how can I control the UV rotation per object while using the same VRAY Material?
    First I would assign a Rhino box mapping to all objects with the same material and adjust size or repeat until it looks right scaled. Than adjust rotation and placement of single objects.
Name:	Screen Shot 10-30-22 at 09.35 AM.jpg
      Thank you, this works.but it does require a bit more tweaking and work when the geometries are blocks within blocks.
