Enmesh - what doe's the spacing Z? Plus some wishes.
  • Enmesh - what doe's the spacing Z? Plus some wishes.
    I tested the new Enmesh feature and I'm impressed, it looks very promising. Thank you for adding it.
    I ask me for what can be used the spacing Z option? Spacing X and Y create a gap between the repeating objects, but we have no repeating objects in Z.
    And I have two wishes:
    - Could be added rotation options for x and y also? Best with randomize option.
    - Please add options to lock the current ratio between the x/y/z spacing sliders, same for the U and V tiling.
    Micha
    And one more wish - could a negative spacing allow to move the objects together without parts of the objects get missing?
Name:	Screen Shot 11-09-22 at 07.42 AM.jpg
      Here an example where I miss a negative spacing without clipping:
      spacing 0
      spacing -15
        Hi Micha​,
        This is a good question : )
        There is no real reason for this parameter in the context of Rhino.
        Note that in 3ds max there is no spacing control - there you set the size of a crop box (and Z is basically the Z axis size).
        This crop box can also be translated and rotated.
        However, in Rhino we decided that we can go with the much simpler to setup spacing concept where the crop box is automatically set to the object's bounding box and then the spacing allows you to add space between the instances.
        Bottom line is - if we stick to the current UI and workflow we can remove the Z...
        I have to think about this one but thank you for the suggestion.
        This is easy to do.
        Do you want the aspect to be preserved or set to 1 when you enable the lock?
        I'll have to talk to the devs about this one but there is certainly a use case for it.
        Regards,
        Konstantin
          I would like that the current aspect is preserved for a lock. It's more universal.
          My example renderings shows an useful case - I would like to connect the rings to a closed structure.
            What I meant to say is that I agree with you - your example usecase makes sense.
