Enmesh - wish: multiple materials
  • Enmesh - wish: multiple materials
    I'm looking for a way to apply different materials to the different meshes, but I found no way. Also the Object ID doesn't work. Could be nice if the materials of the source objects could be used.
    Is GPU support for Enmesh on the way?
    -Micha
    Assigning materials to a single item's faces will let you use the Material ID option.
    Click image for larger version  Name:	Enmesh01.jpg Views:	0 Size:	388.6 KB ID:	1169246
    However this is quite a bit limited and might not help in your project.
    I'll log a feature request for the object ID workflow that you're after (VRW-3931).
    Yes, this is one of the top priorities for the GPU team right now.​
