Invisible ground in reflection
  • Invisible ground in reflection
    Hi, is there a way to acheve a render where the ground receive shadows and reflexions, but not visible in reflections ?
    I do not understand.. please try to describe more detailed. Where is your problem?
      In others words, i don't want to see the ground in the cylinder.
        maybe it's not the ground.. but more the horizon what we see there?
          which materials do you use for the cylinder and the ground?
            Hello nicobo,
            You can try making the ground material perfectly reflective (with white Reflection color and 1 Reflection Glossiness), then you should not be able to see the ground in the cylinder reflections so clearly.
            Kind regards,
            Iva
            Iva Mancheva
            V-Ray for SketchUp | V-Ray for Rhino | QA
            www.chaos.com
              I would add this to the ground material and disable "visible in reflections". I hope it works.
Name:	Screen Shot 12-13-22 at 11.45 AM.jpg
Name:	Screen Shot 12-13-22 at 11.45 AM 001.jpg
                An other interesting option is to fade out the reflections for the object metal material.
Name:	Screen Shot 12-13-22 at 11.48 AM.jpg
                  Thanks a lot Micha, works perfectly and solve another issue with the Dim Distance i had.
