Hi there,
Is there any way you can retain multi material information on a single object in a proxy vrscene, and thereby have the ability to choose which ever you need in the proxy scene parameter of your main file? When opening such a vrscene, the materials are actually there with multi material ordering, but registered as orphaned...
An example, a chair with 5 different textile options as multi material, where all would be selectable through the proxy editor (rather than having external blocks with the added materials and layers in the main file, or 5 different proxies to interchange as I am currently doing).
On a side note, as vray has the option to render animations included in a proxy vrscene, how exactly does the animation parameters of the proxy work, as opposed to the render animation parameters? As a test I’ve tried exporting a vrscene of the same chair from GH, with different materials on 3 frames. These frames (and materials) I can select/change to the one I need, but only through the render animation parameters, - it doesn’t seem to work through the proxy parameter.
Thanks,
Thanks,
