Outlines - exclude layers/objects/materials
  • Outlines - exclude layers/objects/materials
    Hi! Is it possible to add in some hotfix this feature?:
    To be able to exclude/include layer/object/material in outlines mode. Withouth this is problem wit greenery which have too many outlines (especially leaves, etc...).
    Thanks
    Pavel
    ​Hello, Pavel,
    The Outlines effect can be altered or excluded individually for each scene material.
    Here is an example of a very simple model with Outlines effect enabled (the tree is a Cosmos asset).
    Here are the steps needed to exclude the tree from the Outlines overlay:
    1. Merge the Cosmos asset to get access to its materials.
    2. Select one of the Tree materials and add an Outline attribute:
    3. Lower the Outline attribute's opacity to 0:
    4. Repeat the previous two steps for every other material used in the tree asset.
    End result:
    Hope this helps!
    Peter Chaushev
    Let's keep in touch
