Edge texture (rounded edges) only in GPU mode...?
  • Edge texture (rounded edges) only in GPU mode...?
    Hi at all,
    after switching from Vray C4D to Vray Rhino I´m completely new to some points...
    I noticed an inexplicable behaviour when using an edge texture to get rounded edges - it only renders on RTX and not in CPU. Since my CPU is way more powerful than my GPU, I´d rather render on CPU.
    Would be kind, if anyone could help...
    Regards Jürgen
    Hello jrgen_halmer,
    Edges texture is working both in CPU and GPU in latest 6.20.04 V-Ray version. Could you please share what version you are currently using? Please check V-Ray>Help>About V-Ray window.
    Also let me take a look at how you create Edges texture - please attach a simple scene with a box and your material here on forum.
    Note that you need to add a second Bump Attribute and set Mode / Map to Local Space Bump. Add Edges texture into the Texture Slot.
    Click image for larger version  Name:	1210474-edge-texture-rounded-edges-only-in-gpu-mode.jpg Views:	0 Size:	555.9 KB ID:	1210517
    Natalia Gruzdova | chaos.com
      Hello Natalia,
      thanks. I did another test, and there it worked...Maybe I did something wrong...
      So far, it seems to be solved. If I could reproduce it again, I would post that...
        No problem, glad it is working now.
        Contact us again if you need any assistance or have questions!
