triplanar on meshsphere
  • triplanar on meshsphere
    Hi there,
    I stumbled on something, i do not understand and wanted to get some help.
    So i testing triplanar on a spherical geometry, and getting issues with using on a mesh sphere.
    See rendering attached.
    First is a regular nurbs sphere. (from left)
    second is the same nurbs sphere converted to mesh.
    third is a meshsphere (triangles)
    fourth is a meshsphere (Uv)
    last is meshsphere quad.
    All rendered with the same material(just grey with a triplanar normal map on)
    Do you know where Mesh (triangle) and Mesh (Quad) doesn't get the triplanar normal map?
    best
    Hello citro3101,
    Tri-Planar mapping and also any texture mapping will work properly with V-Ray if you apply a Spherical mapping (from Rhino Properties > Texture Mapping) to the Mesh Sphere with Triangles and Quad Style.
    Kind regards,
    Iva
    Iva Mancheva
    V-Ray for SketchUp | V-Ray for Rhino | QA
    www.chaos.com
      Thank Iva,
      The reason i wanted to apply triplanar on a "blob" not sphere, but yes it works If I create an UV map on them, just wondering why the other mesh types takes on triplanar without adding an UV.
