V-Ray 7 Beta license error
  • V-Ray 7 Beta license error
    Hi konstantin_chaos
    I installed VfR 7 but I get an error if I start to use V-Ray. What can I do?
    The license server show me that all v6 licenses are free, non is in use. Is a V7 license needed?
    Also is the folder "C:\Program Files\Chaos Group" not used for installation anymore? There is no V-Ray folder inside. (In the past it helped to rename this folder for parallel installation of different V-Ray versions.) Looks like the folder "C:\Program Files\Chaos" is be used now.
      OK, looks like a parallel installation is possible. Only there seems to be no license for VfR 7 available. The beta is not free forVfR6 user?
        Hi Micha​,
        The beta is for all V-Ray subscribers.
        If you have a subscription, you should have received a V-Ray 7 beta license automatically.
        Can you please send me more details about your Chaos account in a direct message?
        Also note that V-Ray is now installed in the Chaos folder instead of in Chaos Group.
        Regards,
        Konstantin
          Originally posted by Micha View Post
          Hi konstantin_chaos
          Same issue here...
          konstantin_chaos Can you help? I sent you a private message
            Hello Micha and Grigio18,
            We have provided both of you V-Ray 7 licenses for the duration of beta testing. Please try using V-Ray and let us know if you can open Asset Editor and render successfully.
            Natalia Gruzdova | chaos.com
              Great, it works.
                Where is the best place to talk about Beta issues?
                  Found it - https://forums.chaos.com/forum/v-ray-7-for-rhino-beta​
