Fresnel reflections
  • Fresnel reflections
    I?m not sure if this is a bug and it?s pointed out before, but here is some images which I?m not sure why they are behaving strange !?!?
    It seemes like the MAP-image is not rendering out if the ?Fresnel reflection? is not turned ON?
    You can see the image nr. 2 have the same settings as the image nr. 3 but the ?Fresnel reflection? is turned OFF on image nr. 2 ???
    Best regards
    //A
    est regards,
    <br />//A
    Fresnel reflections
    Comput,
    In image 2 if you want your map to show and you want reflections with no fresnel you must make your reflection color closer to black. Right now you have made a 100% mirror if your reflection color is white.
    Corey
    Corey Rubadue
    Director
    Chaos Group
      Fresnel reflections
      Fresnell doesn't mean reflection, it is a property of reflections, so turning it off doesn't mean you'll get no reflections.
      Read this:
      http://www.neilblevins.com/cg_educat...l_and_refs.htm
      scroll down for "fresnell and ior", that should clear things up!
        Fresnel reflections
        hey Wouter,
        I read that one sometime back. Neil does a nice job with his explanations.
        ....good source.
