In the interest ....
  • In the interest ....
    Hello all,
    There's many here with no prior Vray experience, and of course, there are those with a good amount of experience through Max. In the interest of accelerating the testing, please try and share your settings for lighting and materials as much as possible for those at the bottom of the learning curve. More people doing more advanced things will equate to a broader analysis and will only serve to expedite the process.
    Thank You,
    I second that!
    (Speaking from the bottom, of course.)
      I third that. I'm still geting nothing but black....
        Explain your scene setup for specific help, but as a general tip I would start off using a rect light or direct light at first until you get used to falloff settings. The positional / spotlight falloff pretty quickly and need large multipliers.
        Joe Bacigalupa
        Developer
        Chaos Group
          This may be of some interest: The built-in Irradiance Map presets in 3DS Max.
          Range from Very High to Very Low quality setting.
          It does not explain anything but it shows a lot...
          This help me to improve the quality of my rendering with VFR...
          Cheers
            We have made these - ftp://asgvis.com/pub/visopts/
            Corey
            Corey Rubadue
            Director
            Chaos Group
              Corey, please implement the presets in the installed files. I suppose so, new users dosn't find the link here.
                I'll be sure to put them in the installer. I wasn't aware that these existed
                [edit]
                Also, to be clear. The visopt file format is an entire representation of all of our options - it is not the same as in Max where those presets are just for certain parts of the options.
                Joe Bacigalupa
                Developer
                Chaos Group
                  Hi, can anyone tell me what the files do and how do I use them?
                  Cheers
                  http://www.dotsan.com
                    Visopts files simply save your render settings. When you open the render options window for Vray, in the upper left is "file." Pull that down and you can load pre-saved settings or save your own for future use. There are a bunch that come with Vray- when you first pick "load" it should show you the list.
                      Thanks.
