Caustics quality
  • #61
    Caustics quality
    Vlado, thank you for your test and the suggestions.
    I have here a AMD 3800X2 machine and I see two render buckets only, is it right? I think, it should be four buckets. Can you help please?
    • #62
      Caustics quality
      Originally posted by vlado
      The caustics photon map settings were 30,000 caustics subdivs for each light; in the render settings: search distance: 0.2; max photons: 0; max. density: 0.04. I'm not sure if the scene scale is the same between the different versions of the file though.
      The resulting photon map was huge, a little less than 3GB, but this was not a problem since I rendered the scene on a 64-bit machine with 4 GB of RAM under WinXP 64-bit edition. Even though I used a 32-bit version of V-Ray, the 64-bit version of Windows can give a lot more memory to an application than the 32-bit version.
      Also, I should note that the machine was a dual dual-core AMD Opteron at 1800 MHz, so that means 4 rendering threads. If I had to render on a single-processor machine, it would have been about 21h of rendering.
      Other than that, the primary GI engine was irradiance map, and the secondary - light cache with 1000 subdivs. "Use light cache for glossy rays" was off. AA was adaptive QMC 1/100, and the noise threshold was very very low - maybe about 0.0004.
      Also, while testing the scene, I found a bug in the photon mapped caustics - they were darker than they should be, so I had to fix this first.
      Anyways, it's a very difficult scene (precise caustics in V-Ray in general are hard to deal with); although V-Ray did a fairly good job in the end, I think it should be possible to make it better and faster with less memory... just need to figure out how
      Vlado,
      Awesome
      Thank You for sharing the settings.
      I had tried a 25000 photon map on my machine (1gb ram) and then played with Max density to limit the size of the map .... but I run into an unexplained problem that vrayFroRhino would abort. I didn't have time to troubleshoot and pin down the issue and so didn't file a report on that yet.
      Yes, we need some magic dust from Vlado
      If it would be possible in the future to configure Vray and render this scene on a single proc and bring down the time to less than 5h at this quality ... it would blow my socks off !
      -Thomas
