Here is a small zip file with some files I used to create a HDRI map, using the spherical camera and the override fov=360. That way you create a latitude/longitude map, which can be used as an environment map if you use the 'spherical' mapping type.
In the zip is one file for the hdri creation (note how the camera is placed). The other 3dm is a scene where I use the hdri (note the gamma color mapping) and the hdri map itself.
Hope this helps anyone
http://www.aversis.be/vrayrhino/hdri.zip
