Is there a way to control the amount of bump?
bump height?
bump height?
The current vray is using a exotic blend function for the textures.General if you like to change the intensity of a texture, you must set the color to black and than you can use the texture multiplier. Vray blend between the color and the texture. If you use black, you get a pure intensity control.
In the case of the bump, you can not set any color, you can find a multiplier at the texture properties.www.simulacrum.de - visualization for designer and architects
bump height?
Originally posted by MichaThe current vray is using a exotic blend function for the textures.General if you like to change the intensity of a texture, you must set the color to black and than you can use the texture multiplier. Vray blend between the color and the texture. If you use black, you get a pure intensity control.
In the case of the bump, you can not set any color, you can find a multiplier at the texture properties.Best regards,
Joe Bacigalupa
Developer
Chaos Group
bump height?
Originally posted by joebOriginally posted by MichaThe current vray is using a exotic blend function for the textures.General if you like to change the intensity of a texture, you must set the color to black and than you can use the texture multiplier. Vray blend between the color and the texture. If you use black, you get a pure intensity control.
http://www.asgvis.com/phpBB2/viewtopic.php?t=375www.simulacrum.de - visualization for designer and architects
