2D Trees and peoples at planes aligned to the camera script
  • 2D Trees and peoples at planes aligned to the camera script
    in the rhino forum I have got a very nice script good for arch viz. Now we can use 2D textures of tree and peoples with opacity map (I think it will be ready in the next releases) at camera aligned planes.
    The script helps to align the planes with the texures to the camera again after the camera was moved.
    -Micha
    Here the script ready to copy to a rhino button:
    Code:
    _-runscript (orientBillboardsToCamera
    Sub orientBillboardsToCamera()
    	Dim objects
    	objects = Rhino.GetObjects("Select billboard surfaces", 8,, True)
    	If Not IsArray(objects) Then Exit Sub
    	Dim redrawing
    	redrawing = Rhino.EnableRedraw(False)
    	Dim cameraLine, flattenedCameraLocation
    	cameraLine = Rhino.ViewCameraTarget
    	flattenedCameraLocation = setZ(cameraLine(0), 0)
    	Dim objectID
    	For Each objectID In objects
    		orientBillboard objectID, flattenedCameraLocation
    	Next
    	Rhino.EnableRedraw redrawing
    End Sub
    Sub orientBillboard(objectID, flattenedCameraLocation)
    	Dim centroidPoint, centroidUV, centroidNormal
    	centroidPoint = Rhino.SurfaceAreaCentroid(objectID)
    	centroidUV = Rhino.SurfaceClosestPoint(objectID, centroidPoint(0))
    	centroidNormal = Rhino.SurfaceNormal(objectID, centroidUV)
    	Dim referenceLine, targetLine
    	referenceLine = Array(setZ(centroidNormal(0), 0), setZ(centroidNormal(1), 0))
    	targetLine = Array(referenceLine(0), flattenedCameraLocation)
    	Rhino.OrientObject objectID, referenceLine, targetLine
    End Sub
    Function setZ(point, value)
    	setZ = Array(point(0), point(1), value)
    End Function)
    nice script
    sweet! Very useful, thanks Micha
      i couldnt get this work
      the script only rotated the plane a bit
      should i preload the picture to the plane as decal or something
      i copy pasted the text to a button
      not worked
      i saved the text as rvb
      not worked
      i use rhino 3 sr5
      can anyone help me on the subject
      do dot.net 2 required or so
        Try this one.
        PS:You must edit the toolbar button to get real location of Billboards.rvb
          ALTO, do you have a new script?
            Yes is different from yours try it!
              Ah, a nice icon and an option dialog. But I get an error, so that I can not test it.
              I translate from german:
              Code:
              Source: runtime error ...
              Error: object is no list
              line: 74
              char: 0
              code: 0
                Script is not mine, i've only edited a little, created icon and toolbar.
                I think you've got this error because first you should select billboard objects (click with RMB) and then click LMB to autorotate.
                PS You can always invert LMB with RMB command
                PPS This script works with surfaces only!
                  Ah, I understand: all billboards can be turned later without selection again.
                    Re: 2D Trees and peoples at planes aligned to the camera script
                    Hello ALTO,
                    any chance to get this button&script working for Rhino 4 please.
                    -Micha
                      I see ALTO's post above, but I don't see a link to download the script. I need it for Rhino 3.0? Can someone post it? (Old forum links don't work.)
                      Thanks,
                      Craig
                        http://fileho.com/download/b20485602...cript.rar.html - are you talking about this one from the following post? I'm seeing that it has been deleted from where it was originally posted due to "abuse". Who knows...
                        Originally posted by ALTO
                        Try this one.
                        Joe Bacigalupa
                        Developer
                        Chaos Group
                          That's the one. Admit it, Joe, you were rendering naked teens again!
                          But seriously,
                          Anyone got it?
                            Searching through my computer I found some Billboard Scrips (orient to camera is one) I packaged them all together.
                            http://s6.fileho.com/download3/b2048...hinoScript.rar
                            I just hope fileHO doesn't find these 'improper' again. :
                            • #15
                              I thought you said you were going to keep that between us? I can't trust anyone these days...
                              Joe Bacigalupa
                              Developer
                              Chaos Group
