3 part question regarding textures
  • 3 part question regarding textures
    This is a 3 part question regarding textures,
    1)In the material editor, on the right side I drop down the diffuse click on the ?m? next to colour, browse my texture files, if I bring in a wood grain BMP file and click on the update preview button it shows my wood grain as grey. If I do the same but with a jpg wood grain it look ok.
    2)Once I have my wood grain in the material editor how can I scale my textures?
    3)How do you set gloss and reflections? I tried adding a reflection layer but nothing happens when I render, no gloss finish
    Any help would be greatly appreciated
    Regards,
    MarkO
    MarkO,
    You have run into a few bugs that are now fixed in the most recent build of V-Ray for Rhino.
    This is fixed.
    You can use RCM mapping tools to scale, rotate, and position your textures. Go to Object Properties>Mapping.
    You are correct in adding a relfection layer. I am not sure why nothing happens. I would need to see your material settings to tell you what is going on. What you will need to do here is apply a Fresnel texture or reduce the reflection color from pure white toward black. Otherwise you will end up with a mirror.
    Corey
    Corey Rubadue
    Director
    Chaos Group
