material layer transparency / texture multiplier
  • material layer transparency / texture multiplier
    ... i am a little confused here, as far as i understood, by the transparency color you can control the influence of the specific layer (the darker the color, the less the influence, am i right?
    In which way does the multiplier affect a texture? is this similar? What does it do if you raise the multiplier to something above 1?
    thank you for your answer
    Andy
    Re: material layer transparency / texture multiplier
    The transparency actually controls how much it lets light go through a layer. If the transparency is black then no light makes it through the layer, thus any layers beneath it are cutoff and will not be visible.
    For most textures other than emitters / bump the texture multiplier acts as a mix ratio between the color and the texture for a given thing. For instance, if you are selecting a diffuse texture and you set its multiplier to 0.5 you are blending evenly between the diffuse color and the diffuse texture. A mulitplier of 0.0 would yield only the diffuse color, and a multiplier of 1.0 will yield nothing but the texture.
    I need to change the UI so that the multiplier ranges / increment changes based on the situation at hand, for a bump map a -20.0 multiplier may make sense, for an emitter a multiplier of 100.0 might make sense, whereas anything outside the range of 0.0 - 1.0 really doesn't make sense for most other textures.
    I hope this clears it up a bit, it is still a work in progress after all
    Joe Bacigalupa
    Developer
    Chaos Group
