thick thin
  • thick thin
    I am not sure, but is there a way to model just a surface and it acts like s little thick solid (usefull for a glass).
    Thank you.
    refraction inside a surface...
    Jp
    Freelance Industrial Designer - Rhino3d v4 - Vray for Rhino
    thick thin
    There is the Mtl2Sided in V-Ray for Max which is good for things such as paper. I'm not sure if this would help with glass or not. Currently it is not available in VfR (no making a material doublesided is not the same thing ). It is, however, being used in our development version of V-Ray for SketchUp - so it will be brought over to V-Ray for Rhino3/4 in the future. Until then I'm sure another user has found a way to get that desired effect, but I'm not sure off the top of my head.
    Joe Bacigalupa
    Developer
    Chaos Group
      thick thin
      I will model a real thickness... too bad...
