Billbord question
  • Billbord question
    Hi
    I'm making my first billbord introduction and I just can't stable it.
    Sometimes I remore all the geometry from my window and render just the billbord and it's ok, then I show the layers with the rest and the billboard is crazy like the image.
    Any solution to stable this?
    Sorry for the English but also not my natural language.
    Thanks
    Sergio
    Billbord question
    ... looks like your texture has an offset at the plane. If I create billboards, than I use the pictureframe command. So you get a plane with the right ratio.
      Billbord question
      your girl also has a texture problem. remove the tile checked, place it on the same ratio on a flat to Cplane Surface. Then rotate or better create a block and then do what you want without risk of texture weird acting.
      ...and she's a little to far for this step to the building
      Freelance Industrial Designer - Rhino3d v4 - Vray for Rhino
        Billbord question
        Thanks I discoverd the problem.
        I also inserted the picture with pictureframe but the problem was that I changes the control points of the surface to pull it down a little so I mess the image up.
        I just inserted the same image and it's done.
        Thanks
        Sergio
