material used for the light bulbs on homepage
  • material used for the light bulbs on homepage
    i'm having a hard time recreating the material used on the light bulbs, any tips
    Re: material used for the light bulbs on homepage
    Just a guess...there is a ceramic material in the library...try to whiten it up a little and add some emissive layer.
      ... since the emitter layer is in front of all layers and hide they you must set the emissive layer transparent (f.ex. at 90% --> ~ (240,240,240)) and increase the intensity until it looks fine.
        I know i'm new here, so I really hate to ask this:
        Where do I set the layer transparency?
          Each layer at a material support a transparency (color). If you set white (255,255,255) than it means 100% transparency (for each color channel R-G-B).
            thanks for refreshing my poor memory micha
            however, the tweaking is a pain - too high emitter = no decal is showing, too low = no emitter effect on groundplane
            what am I forgetting
              that helped thanks
