I lay down (unwrap) UV map (in another application), and export object in Wavefront .OBJ format, which keeps UV map. Can I use this uv map in Vray for Rhino, does Rhino import UV map too, or not? And how can use this UV map with RCM tool?
Thanks for any answer.
[EDIT]: I found solution, so moderators can delete this post.
