Rhino 3 batch render....
  • Rhino 3 batch render....
    I have downloaded from your tools section the batch render for rhino 3
    I have noticed that there is a bug with view....but i cannot understand!
    If i want render in the night for example 5 views ok?
    For example the name
    view1
    view2
    view3
    view4
    view5
    Mmmm in the batch list...how i can set them for work properly?
    Thanks VERY MUCH! ???
    Re: Rhino 3 batch render....
    To add a render to the queue you just need to select which file and view you wish to render. When you've added all the views you want to render you hit start to begin the render process. Have you gotten this far? What is the bug you've noticed?
    Joe Bacigalupa
    Developer
    Chaos Group
      I seem to be having the same problem. In order to get the batch render to work in Rhino3,I have to set up four named views in the four viewports and save the file before running "BatchRender". It DOES NOT load the Named Views correctly. I don't know if the "SetActiveViewport" command, which the "batch render" script seems to be using, was made more robust in Rhino 4, so that it can actually load a named view, but it doesn't seem to be doing it in Rhino 3.
      Furthermore, it does not support viewports named with spaces.
      Any help you admins can give would be great because this tool is a great idea.
        Ok - I'll have a look at the code. I'm not sure why it would need X number of views to let you choose one.
        Joe Bacigalupa
        Developer
        Chaos Group
