LED lighting
  • LED lighting
    Hi everyone,
    I'm trying to render a whole bunch of LED lights and looking for the most efficient way of creating an LED effect. any suggestions?
    is there a self illumination option for V-ray materials?
    Cheers,
    Mani
    Re: LED lighting
    Look at the material tutorial here:
    http://www.asgvis.com/index.php?opti...d=30&Itemid=55
    For LED best you use an emitter material with a texture, so the LED dosn't looks so homogenous. Good, if you place the emitter within a plastic housing (colored "glass" material + enable "affect shadows").
      Re: LED lighting
      what should be the map used? a real led photo?
      www.leobonilla.com
        Re: LED lighting
        Yes, a frontal photo direct in the lens. It's not a must, but looks better than a simple colored emitter only. You can use a radial color gradient too, but maybe this is looking to perfect. It's a question of how much detail is needed.
