Batch render
  • Batch render
    Hello,
    i already searched for the topic but didn´t find something for my problem.
    1. When i start batch render Vray renders one view
    (i want three to be rendered)
    -but only one picture is rendered- the others dont open!
    It just works if i open each desired perspective in its own viewport.
    How can i change?
    Or is this the way to render the different viewports?
    Greetings
    Jonas
    Re: Batch render
    It should render all the views that you have queued. Some other users have reported problems with the batch render plugin. Could you send me a scene that causes the batch render not to work? And let me know which views you add and in which order. If I can reproduce it I can fix it. Thanks
    Joe Bacigalupa
    Developer
    Chaos Group
      Re: Batch render
      I think I MIGHT have solved the mystery!
      In order to Batch Render, in Rhino, you need to activate all the views you want to render in your file. if you have, say, 3 views tha you want to batch render, then you will need to change three of your current views to the views you want to render. i.e. change top view to one, and left view to another .... etc so if you want ten views to batch render, then create 10 viewports, w/ the views activated.
      I'm testing it right now, i think it's working so far. Will keep you updated, but if you don't hear from me then it's working.
      wish me luck.
        Re: Batch render
        I think your right...
        thats the way i did the batch render!
        I just thougt there would be an other way :
        all saved and loaded perspectives which are loaded into batch render would be rendered in order
        but when i know it doesn`t work like that it´s okay
        greetings
        jonas
