This might be a dumb question but is it possible to shut off object reflections? Like if there are two object in a scene and they are reflecting off each other? thanks in advance!
Object reflections?
Re: Object reflections?
I know this problem too, if I render jewelry in a closed studio scene and the stones should show reflection of HDRI only. So, my wish is a option like this "show env reflection only".www.simulacrum.de - visualization for designer and architects
yes, not only that but when rendering reflective metals such as gold or silvers on colorful or textured ground planes you get nasty metal reflections that massacre the metal.
also with the stones, if you have a light object like a rectangle light, it will block the env map on the stones as well. very frustrating.
Originally posted by Travis Serioalso with the stones, if you have a light object like a rectangle light, it will block the env map on the stones as well. very frustrating.So, the rect light should not block the env.
