GLOW
  • GLOW
    vray for rhino and glow effect???
    Re: GLOW
    You can add emissive (light-producing) layers to a material to make a glowing material. I'm not sure if that is what you are asking or not. If you have the physical camera enabled you will need a significant multiplier on it to get an effect and GI must be enabled as the emissive layer is not a direct light source.
    Joe Bacigalupa
    Developer
    Chaos Group
      Re: GLOW
      the emissive layer is different to the glow effect that i want to do... review the same effect in 3dmax (post producction lens effect) i can see in the new options of vfr (in the rhino options window) the rendered support options says "glow" but this not change nothing...
