background image
  • background image
    Background image doesn't appear in rendering.
    I choose Environment - Background - M and select Bitmpap, I select a jpg file to display, but it doesn't appear in rendering. It works only if I use it as environment.
    Maybe there is some parameters to change that I don't know.
    Someone can help me?
    Re: background image
    Background image isn't supported. You can set spherical 360° environment texture or create a surface with a textured emitter in the background.
    Or you render your object without background and combine it in photoshop. If you save a rendering in png format and open it photoshop, the empty background is transparent.
      thank you, it is very clear.
        could you explain please, in the future release , will be supported "rendered background image" ?
