Bump map problem
  • Bump map problem
    Hello!
    I have a problem with a bump map. I want it to go "over" an edge, but I get the following result. How can I avoid this?
    Best regards
    Magnus Svensson
    Re: Bump map problem
    Try "box" mapping instead "planar" mapping at the Rhino mapping properties.
      Thank you for your quick answere!
      I now tried "explicit map channel" instead of "object xyz" and that worked fine. I didn´t get a good result by doing that before, but I have made some changes and it looks good now.
      Thank you!
      /Magnus
        Right, "object xyz" is needed very seldom. I used it for the infinite plane only.
