why should it be? The purpose of IES light is to be able to reproduce the exact intensity and luminosity the manufacturer choose....
If it is not bright enough,may be use a higher intensity light.
AFAIK the primary goal of IES lighting is for accurate light distribution. There is intensity data that goes along with that, but there should still be ability to adjust the base intensity. So far, I haven't found anything specifically that says that you shouldn't be able to adjust it.
