Help with output size
  • Help with output size
    Have always used Rhino for my CAAD work and so when VRay for Rhino came out I started to use it and try to do my own visualizations too.
    However I am a novice when it comes to this.
    My problem is rendering to a big enough size.
    I need visualizations at A3 size
    that is
    297mm by 420
    and with a high DPI <200> if possible
    even using the VRay preset of v.high
    I still can't achieve the results that I want, at the quality I want
    I assume that I have to change something in the "Output" drop menu
    I'm just not sure what....
    Any advice would be grateful welcome
    Am I being over ambitious?
    Re: Help with output size
    If you don't want to calculate the size, than open Photoshop and start a new document - set image size 297x420 mm and resolution 200. The new image is 3307x2339 - that's your size for the Vray output.
    A VfR integrated DPI-size calculater at the output options could be nice.
