Runtime Error!! when rendering with Maps
  • Runtime Error!! when rendering with Maps
    Help!!
    I am at work trying to finish up some renderings and when I render a scene with maps Vray / Rhino crashes immediately. The same scene with the mapped objects hidden renders fine. I didn't have this problem earlier but I just got a new computer today (much more powerful) and maybe there is a conflict of some sort??
    Any ideas?!
    Thanks!
    Kevin
    Re: Runtime Error!! when rendering with Maps
    Hello d.,
    I´ve got a same problem with last SR RC1. Sometimes i had to erase or hide some surfaces with textures becouse render dont start.
      check if you are using bitmaps that load but don't work well. Damien mentioned that png's are not always in the correct format and can cause troubles. jpg's are safe and should work. Or open the troublesome map in photoshop and resave.
      You can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
        What size are the maps? Very large?
          It's very odd .. after awhile it started to work. And I don't know what I did differently to change it!
          Anyway, my maps are a bit large so I will take that into consideration as well as resaving them when having an issue.
          Thanks!
          k
            Also, take a look at your RAM usage. At Win32 OS Rhino will crash at 1.6GB, maybe the 3GB switch help, better use XP64 or/and try some of the render tool tricks (sticky thread at general forum).
              I have the same problem.
              I posted about it the bugs section
              http://asgvis.com/index.php?option=c...0&topic=3539.0
              includes a jpg you can use to recreate the crash.
              solution: re saved jpg as a png and it worked.
                I had the same problems with my most biggest scenes.
                As soon as i removed the displacement maps of the scene or change them to Bmp, its worked fine...
