Hi guys,
so i have a question.
i have 3 part which make up a gas mask for a hospital. They are made of transparent acrylic.
I create a standard glass from the standard library. I turn on fog shadow and alpha and turn on double sided. I have added a slight colour to the fog colour to get that little blue in the platic.
2 parts are small and the 3rd is the full mask. They are all just as thick though (2mm)
i have a problem with the large part. It seems to render bright green or bright red or black depending on what section of the RGB field i take. Its not nice and transparent like the other parts. The part works fine if i take the fog colour to white. It also seems to become slightly lighter if i set the fog intensity to 0.005....but that seems a bit low
Ive had this problem before with a washing machine door.
Any ideas? have you seen this problem before?
Justin
Justin
