Distributed Render problem
  • Distributed Render problem
    Hi all,
    i have purchased some computers to make a small renderfarm, but we have a problem if the machine used for the process of DR are superior of 2.
    these machine are a dual xeon (8 cores each).
    Everything is ok in a very very smalls scenes, not the same in a ordinary project, like a ordinary "medium" scene file like 80mb of data.
    Any suggestion?
    thanks.
    Re: Distributed Render problem
    What is the problem you have when you have more than 2 machines working on DR? Does it crash, or not render properly?
    One thing to check would be to make sure that all of the machines are running the same version of the DRSpawner. Different versions of the spawner working together can be a problem.
    Joe Bacigalupa
    Developer
    Chaos Group
      if i try a render with 2 hosts, the render starts.
      if i try with 4 hosts, only my "client" machine start to render.
      here is the info:
      Beginning render sequence
      [RenderView] startCameraTime=0.000000, endCameraTime=0.033333
      [RenderView] numCameraTMs=2, numFrames=1, frameSamples=2
      Initializing built-in VFB.
      Starting DR
      Connected to render host 192.168.1.6
      Connected to render host 192.168.1.16
      Connected to render host 192.168.1.19
      Connected to render host 192.168.1.20
      Using 4 hosts for distributed rendering.
      Preparing camera sampler.
      Preparing ray server.
      Creating and initializing 4 thread(s).
      Allocating memory for build data of 5697261 faces (159523308 bytes, 152.1 MB).
      Initializing face build data.
      Creating 'done' event.
      Starting first thread.
      Waiting for thread completion.
      Releasing thread resources.
      Preparing faces for intersection tests.
      SDTree statistics:
      Total number of faces stored: 5697261
      Max tree depth: 47
      Average tree depth: 26.857
      Number of tree nodes: 591108
      Number of tree faces: 11184008
      Number of tree leafs: 268978
      Average faces/leaf: 41.5796
      Memory usage: 334.64 MB
      Scene bounding box is [0,2600.68,-405.264]-[3027.45,5007.31,510.526]
      Preparing direct light manager.
      Preparing global light manager.
      Irradiance sample size is 84 bytes
      Photon size is 56 bytes.
      Light cache sample size is 112 bytes.
      Building light cache.
      Tracing 1000000 image samples for light cache in 4 passes.
      Setting up 4 thread(s)
      Light cache time interval is (0.000000, 0.000000)
      Bitmap file "T:\3d_resource\Textures\Clienti\Grafica_london\QU INTA_1 copy.jpg" loaded.
      Bitmap file "T:\3d_resource\Textures\Clienti\Grafica_london\QU INTA_1 trasp2.jpg" loaded.
      Bitmap file "T:\3d_resource\Textures\Clienti\OGGETTI PATCH\DOGHE_SPLIT.bmp" loaded.
      Bitmap file "T:\3d_resource\Textures\Clienti\OK_for rhino\Body mirror.bmp" loaded.
      Bitmap file "T:\3d_resource\Textures\Clienti\Grafica_london\fa ns55.jpg" loaded.
      Bitmap file "T:\3d_resource\Textures\Clienti\MARLB_01.bmp" loaded.
      Bitmap file "T:\3d_resource\Textures\Clienti\RED.bmp" loaded.
      Bitmap file "T:\3d_resource\Textures\Background\HDRI\DOSH EXTREME HI_RES\1\SN\DH211SN.jpg" loaded.
      Bitmap file "T:\3d_resource\Textures\Clienti\ALERONDER.bmp " loaded.
      Bitmap file "T:\3d_resource\Textures\Clienti\BODY01.bmp" loaded.
      Bitmap file "T:\3d_resource\Textures\Clienti\SIDEALERMALB------.bmp" loaded.
      Bitmap file "T:\3d_resource\Textures\Clienti\ALETTONE.bmp" loaded.
      Bitmap file "T:\3d_resource\Textures\Clienti\A.bmp" loaded.
      Bitmap file "T:\3d_resource\Textures\Clienti\OGGETTI PATCH\glasses.jpg" loaded.
      Render host turbo04 (192.168.1.19) is not responding
      Render host turbo05 (192.168.1.20) is not responding
      Render host turbo01 (192.168.1.6) is not responding
      Scene transferred to turbo02
      Scene transferred to turbo01
      Scene transferred to turbo04
      Scene transferred to turbo05
      Render host turbo02 (192.168.1.16) is not responding
      Threads completed
      Merging light cache passes.
      Light cache contains 32399 samples.
      Light cache samples collected; compiling lookup tree.
      Prefiltering light cache.
      1 interpolation maps registered
      Rendering interpolation maps with minRate=-4 and maxRate=-2
      Threads completed
      Calling endPass() on irradiance maps
      Calling prePassDone() on irradiance maps
      Image prepass completed.
      Rendering image.
      Threads completed
      Waiting for DR to finish
      Clearing global light manager.
      Clearing direct light manager.
      Clearing ray server.
      Clearing geometry.
      Clearing camera image sampler.
      Clearing camera sampler.
      Clearing QMC sampler.
      Clearing path sampler.
      Clearing color mapper.
      Closing DR
      Render cancelled
        the spawner are the same on all machine.
          Interesting - it seems to transfer the information to all of the machines...So none of the DRSpawner applications crash when you start the render?
          I am wondering if it is a synchronization issue with 32 cores trying to get up and running.
          Does the render finish pretty quickly with just the host doing it? If so it might be that they are taking a while to all get going.
          If you want to send me your scene so we can test it on our end you should make a support ticket through our Support section and either attach the 3dm file ( if it is under 10MB ) or post it on a 3rd party file hosting website ( like http://www.mediafire.com ) and send me the link.
          Joe Bacigalupa
          Developer
          Chaos Group
            yeah , i try to send you the link of a scene, trough a mail in the support section.
            what is the mode to obtain the support tickets?
            i have a regular licence, but not info about the tickets...
            Anyway, the spawners of the host seems not "receive" nothing than superior of "xx mb"
            it waits....
            Ok, sometime it crash, but in a extreme situation like stop an relaunch heavy scenes from my render client.
            I try also this thing like a DR "host to host" but we have the same problem, only two machine works...
            (note: in this specific scene)
            I suppose is a memory bottleneck, or similar, cause everything is fine in small 3d scenes.
            I don't think is a hardware problem,
            my nodes are equipped with XP64 4gig of ram
              I received your ticket and we'll be taking a look at it as soon as possible. I'll let you know when we make headway on the ticket. Thanks for sending us the scene
              Joe Bacigalupa
              Developer
              Chaos Group
                Joe VRay team,
                this is an enormous issue.
                The users are using DR to render large files - to get the speed up. I figure that is what DR is for.
                Is there anyway to increase the wait time to get the 3D model? It varies time to time...
                Also does teh Spawner have a 'Let Go' command? Post render cancel?
                Thanks, Glenn Johnson > ;D
                  This forum thread was made in April, so it's quite old. This was indeed an enormous issue. As far as we know, this issue was resolved as of an internal build version on May 1st 2008 at 4:52PM EST. This fix would have been included in the SP1 release. We don't use this forum to track or respond to bugs, we have a support ticket system. If you have found that this issue is still happening, please submit a support ticket so that we can work to repair this issue:
                  http://asgvis.com/index.php?option=c...d=3&Itemid=142
                  I'm afraid I don't quite understand the question. Could you elaborate a bit more?
                  When a render is canceled or completed, the DR Spawner will become available for new render jobs. I don't know if that's what you meant by this question though.
                  Devin Kendig
                  Developer
                  Chaos Group
                    Originally posted by luke72
                    Hi all,
                    Any suggestion?
                    thanks.
                    Luke, put the most complex stuff on layers.
                    Then try turning each layer to a mesh.
                    At some point it goes through.
                    Big NURBS seems to be the problem....
                    Hope this helps.. Glenn
                      I think it could be related to an issue I ran into lately. If one of your images is a progressive jpg, then DR will choke on it. Try to turn off maps and see if DR still fails. If not then there is a fair chance I'm on the right track...
