quick composite
  • quick composite
    Hey there,
    Is there a way to render a wallpaper image into the scene? Sans changing the background map to an image?...
    trying to do a clear material over a image that is set as the wall paper, but need to render it in...any thoughts would be appreciated!..thankies.
    ~Krylon
    Re: quick composite
    Alpha channels should get you there...you might want to look into manually setting the alpha contribution if you're running the RC for the SR (material options)...an important setting if you're using a material that has refraction is the Affect Alpha option
