General Sunlight System for Architectural Rendering
  • General Sunlight System for Architectural Rendering
    Hello, I'm finishing my architecture thesis in two weeks and want to start rendering my model. I want to do simply sunlighting to render the model. I will have semi-detailed interior shots and also some large exterior shots. If anyone has a full list of good settings for architectural lighting that looks realistic at an architectural building scale that would be great. I'm struggling with producing the right lighting. Thanks in advance.
    Re: General Sunlight System for Architectural Rendering
    Use secondary engine multiplier 0.8 (interior) and 0.6 (exterior) to avoid to much diffuse light is indirect reflected. Also I set my white wall colors at approx. max 220.
    The sun interreflection between blury surfaces can cause artefacts. That's a disadvantage of the physical sky of VfR (an example is shown at the starterkit thread). It helps to use a HDRI environment (tips at the starterkit) and a directional light (this dosn't create reflections, it create highlights, reflection fake without interreflection).
    I would use LC + IM -> more infos at the starterkit.
