If the hardware crash - how to get VfR running again?
  • If the hardware crash - how to get VfR running again?
    following hypothetical situation: sundaynight, 6 hours until deadline, a backup of all project files exist at a second machine -> the master engine hardware crashs, no contact to the ASGvis team is possible.
    I ask me, what hardware can be replaced and VfR will run again. I suppose so, take the CPU from a slave engine to the master will make, that the master license will not run and can't be activated again or? I ask me, what can be changed, so that the master run immediately again? Can I change the harddisk and restore a hdd image?
    An other option could be, to work in Demo mode. If the activation failed, because hardware is changed, could I activate the demo mode? An internet conection is needed or?
    ... so my thoughts at the last hours of a project.
    Re: If the hardware crash - how to get VfR running again?
    In the event that your computer's hardware has changed enough that your license is no longer valid, you will be able to use a demo license until we are able to make the appropriate adjustments your license.
    Devin Kendig
    Developer
    Chaos Group
      Good to know, thanks.
